Some probably fatal crashes to identify (VIDEO)
Post here if you come across a video or image that you would like identifying.
Jesper Hvid
Permanent Ban
Permanent Ban
Post by Jesper Hvid »
Well, I don't, that's for sure. I think the clip is 20-25 years old, at least. One of the things that made IDing problematic at the old fameflame was the fact that they often muted the clips. Add to that low-quality grabs using the old capture cards. I have to say it's not too much of a problem to me, if no post-1980s items are solved, but would of course prefer to see it all ID'd. I won't be able to, I'm completely in the dark about it. And so are the commentators on [YT], or else they're trolling.
hollie3sa
Post by hollie3sa »
Jesper Hvid wrote: 2 years ago Well, I don't, that's for sure. I think the clip is 20-25 years old, at least. One of the things that made IDing problematic at the old fameflame was the fact that they often muted the clips. Add to that low-quality grabs using the old capture cards. I have to say it's not too much of a problem to me, if no post-1980s items are solved, but would of course prefer to see it all ID'd. I won't be able to, I'm completely in the dark about it. And so are the commentators on [YT], or else they're trolling.
You're probably correct with ~25 years old.
Here's a (most likely incomplete) list of results from Scooter Lambert's career.:
https://www.myracepass.com/drivers/8705 ... ?year=1990
The #11 sprint car following behind (probably) belongs to Steve Kinser. His last name can be heard at the very beginning of the video: "Kinser watching all this from a car length behind"
Still no match on the flipping car.
I'll keep digging...
Jesper Hvid
Permanent Ban
Permanent Ban
Second extension of topic: Legion Ascot Speedway-interest (only 4 items):
The lack of crash footage from this track, I've always found strange. There really is not that much in existence, and one would assume any lost or forgotten material would have surfaced, after all this time.
But I've decided to request only the ID's for serious-looking/significant crashes, and then I'm down to just 4. All together, they form a sort of "mini-tour" of the track, showing various angles. I've managed to solve the rest of the significant ones, and all the various angles, which I'll add to the relevant topic, later. There is no need for an entire separate topic on LAS.
LAS-segment:
#60: Date: 28 March 1934. Only green is required, but all will be welcome.
0:24-0:30 360 degree spin, South Turn.
0:38-0:45 360 degree spin and impact with outer barrier, South Turn.
0:52-1:11 nudged car crashes into barrier and flips dustily, on the backstretch. Rolls like the one mistaken for Wilbur Shaw in the other video (the #3b).
#61: 20 March 1935: Only green is required, but all will be welcome.
0:25-0:30 Two cars touch and one spins 360 degrees in South Turn.
0:36-0:40 #33 spins 360 degrees in South Turn probably.
0:42-0:45 #?? spins in South Turn.
0:49-1:11 Car goes off the track in the North Turn, and one wheel rolls up Ascot Hills and all the way down again.
#62: 23 November 1930. Note: The track was called American Legion Speedway at this time.
https://www.gettyimages.dk/detail/video ... /139522976 <--- link to video.
0:02-0:08 Car loses wheel on home straightaway.
#63: A South Turn, three-car accident. Late 1920s, maybe 1930, as it has the Chicago-crash from British Pathé occurring before it, the #6 in this topic.
Image <--- just a thumbnail for the cropped video.
http://www.historicfilms.com/search/?q= ... t387i0o474 <--- link to video, starts at 1:14:35. Atrocious quality, with sound effects from an aeroplane... :haha:
With the dates, I'd say there's a chance some of these can be solved.
Jesper Hvid
Permanent Ban
Permanent Ban
Jesper Hvid wrote:#31: 3:30-3:34 unknown. I seem to remember this was Australian. I.e. speedcar, and not sprint car.
It's a different angle of the one, here, at 4:15-4:20:
Same, with commentary, at 1:25:
Horrible accident. #55 flips, gets hit right in the cockpit by #68 Bruce Doolan (which then causes #51 to flip), catches fire, then gets hit by #76. All the while, with the driver still inside. It should by Bryan Cunneen, during the "World Championship" at The Royale, or Sydney Showground Speedway, in 1966.
Pic: Image
Aftermath, click to enlarge: Image
We'd already been there: viewtopic.php?f=80&t=13308
Speedcars = Australian midgets, yeah? Or both sprint cars and midgets?
EDIT: http://www.speedwayandroadracehistory.c ... -1966.html <--- this gives the names of the other two drivers: #76 Lou Marshall and #51 Sid Clarke. 26 Feb 1966 is the relevant programme/news bulletin. END EDIT.
Jesper Hvid
Permanent Ban
Permanent Ban
Regarding #3a+b: Archivio Luce has a Legion Ascot-clip with those accidents, and it is dated 8 Jan 1936, which should help immensely. At this point in time, the track's name had changed to Ascot Motor Speedway.
Wheel didn't come off the rolling car. But the date definitely shoots down the Wilbur Shaw-theory.
hollie3sa wrote: 2 years ago
I can't hear the comments on the video here at work, but that must indeed be Kinser in the #11, and he started running green cars when he started his own team in 1995, I feel sure. Lambert was a Californian, and I doubt he raced much outside of his home state, so something in (Northern) California, late nineties/early noughts should do. Maybe Jim Thurman knows? Ah, I forget, Jesper just alienated him on another thread... tough luck.
hollie3sa
Post by hollie3sa »
Michael Ferner wrote: 2 years ago
It's Silver Dollar Speedway
And I think that solves it:
Haudenschild narrowed the gap during the next five laps, and won a back-straightaway drag race to take the lead midway through the race. His stay in first place was short-lived, however, as his 22nd-lap collision with Scooter Lambert sent him flipping over the catch fence on the back straightaway. Haudenschild's crew went to work quickly on the #22, and had it race-ready by the time the fence was repaired.
"Catch fence" - yeah, sure.
Source: https://us.motorsport.com/woo/news/silv ... 6/1662384/
Good find!, So, it's "Haud" he's saying - I listened to that umpteen times, I'd never have guessed!
hollie3sa
Post by hollie3sa »
Michael Ferner wrote: 2 years ago Good find!, So, it's "Haud" he's saying - I listened to that umpteen times, I'd never have guessed!
Absolutely this. I skimmed through llists and lists of names and just could not find anything that appeared even remotely close to what the commentator was saying.
Do you understand what he's saying at 0:14?
"Somehow only one spectator is hurt. Haud's ??? will return after the lengthy red flag."
Jesper Hvid
Permanent Ban
Permanent Ban
Michael Ferner wrote: 2 years agoAh, I forget, Jesper just alienated him on another thread... tough luck.
I didn't realise I could even do that. I guess I must have known what it felt like. You know who to blame: the bastard sons of madwomen. But thanks for the ID.
JThur01
Regular Member
Regular Member
Real Name: Jim Thurman
#56
Post by JThur01 »
Michael Ferner wrote: 2 years agoMaybe Jim Thurman knows? Ah, I forget, Jesper just alienated him on another thread... tough luck.
Michael, nah. Certain folks over at TF have gone out of their way to be greatly inhospitable in hopes of running me off so they can continue with their versions of "truth" :smiley: Compared to them, Jesper is a rank amateur :tongue: :smiley:
Jesper, you're going to have to explain this to me. Who exactly are these "bastard sons of madwomen" to whom you refer? If it's something from "Hamlet", I didn't have any Shakespeare in school, so I wouldn't know :smiley:
Jesper Hvid
Permanent Ban
Permanent Ban
JThur01 wrote: 2 years agoJesper, you're going to have to explain this to me. Who exactly are these "bastard sons of madwomen" to whom you refer? If it's something from "Hamlet", I didn't have any Shakespeare in school, so I wouldn't know :smiley:
Yorick, Yorick,
Metaphoric,
How thus have we come to this?
Lost in time; now, skeletoric,
T'was a glass of your own piss.
hollie3sa
Post by hollie3sa »
Anyone?
JThur01
Regular Member
Regular Member
#59
Post by JThur01 »
"Haud's fine and..."
hollie3sa
Post by hollie3sa »
JThur01 wrote: 2 years ago "Haud's fine and..."
Wow... that was surprisingly easy. Kinda embarassing... :blush:
Thank you very much, Mr. @JThur01, Sir!
